Hi all,
My Corsa Utility Bakkie has an issue with the idle.
the van idles at 1,500 rpm up to 2,000 rpm.
I replaced the ICV with an aftermarket ICV from Goldwagon and reset the ECU by disconnecting the negative terminal.
The idle dropped and was fine for a few hours.
It then went back to 1,500 rpm and also has like a small jerk. sometimes if switch off and start again its idle perfect and then back high. i do sometimes get a fuel smell from the front of the van.
Please assist guys as this is such pain to drive.
Feb 2, 2019 at 1:25 AM
