I replaced IACV valve on my vehicle listed above. The job is pretty straight forward. I replaced it with a brand new part from eBay. The part looked just like the one I removed. The price from from the original was very different. The eBay part was much cheaper.
I started the vehicle and the Rpm's were very high at 2100 Rpm's. It Rpm's would eventually get down to 1100 but would have a tendency to go higher after car was driven. I checked for vacuum leak at least 7 times. I used carburetor cleaner, propane, and water. All lines look fine. I removed the electromagnetic motor which is the black piece. I swapped it out with old one. I knew that one was working fine. Same issue with Rpm's. I must also note that I leaned throttle body well when it was removed. I cleaned mass air flow sensor. I used a brand new gasket when placing throttle body back. Rpm's drop but very slowly when I depress accelerator. Car drives with no hesitation but I do noticed that I get that additional surge one stopping due to Increase in Rpm's. The Rpm's should be around 750.
So I am stuck with this Rpm issue. I tried the idle relearn procedure and reset the ECU. This did not work. I do not think the battery has nothing to do with the high idle. I can hear the idle control valve open because of the high wine but settles down a little. I am
not sure what to do.any advice?
Oct 7, 2019 at 7:29 PM
