High idle after IAC replacement
2000 DODGE DURANGO
141,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
JESSE GIBBS
High idle after replacing IAC.
Nov 27, 2019 at 1:44 PM
Have you checked to make sure there are no vacuum leaks? Something may have been disconnected when you replaced it. Also, what was happening prior to the replacement that prompted you to replace it?
Take a look through this link and see if it helps:
https://www.2carpros.com/articles/engine-idles-too-high
Let me know if that helps and if you checked for leaks.
Nov 27, 2019 at 8:56 PM
