Car had a throttle body wire short circuit and then i had to replace the throttle body with. at the same time i replaced the cam sensor which was broken. i managed to get a used throttle body which has after i installed it was working better then the previous one, but it came with its own problem which is high idling above 1,000 rpm's.
i took my scanner and scanned since YouTube told me i need to do a throttle body adoption but when i scan for faults it told me this 01087 - Basic Setting Not Performed 27-00 - Implausible Signal)
which i don't know how to do i tried using VCDS software to go to basic settings to try it but nothing the idle is still high.
Apr 8, 2020 at 11:37 AM
