High Idle
2005 AUDI A4
117,000 MILES • 1.8L • 4 CYL • TURBO • 4WD • MANUAL
DONALD SHENO
Car has high idle around 1,500-2,000 rpm's when the car is hot. I checked for a vacuum leak and found nothing. I also cleaned the mass airflow sensor. After starting my car up again I found that the idle is jerky and still idles high. The car still drives fine so I assume the problem is with some kind of sensor. Should I replace my front o2 sensor?
Feb 18, 2019 at 4:10 PM
SCGRANTURISMO
  • 4,897 POSTS
This sounds like a problem with your Idle Air Control (IAC) valve. I have included a link for down below to a guide and vehicle specific instructions for the IAC, but it requires some specific tools to go through it. Let us know what you find out.
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
Thanks,
Alex
2CarPros
Feb 18, 2019 at 8:29 PM
DONALD SHENO
Replaced the ICV and it fixed the issue. Thank you
Feb 19, 2019 at 5:07 PM
Good to hear, please use 2CarPros anytime we are here to help.
Feb 23, 2019 at 12:49 PM
