Okay. That is good information. It still could be the IAC however, it is more likely something that is causing your hydrocarbons to be high at idle.
Take a look at the attachment. This will walk you through the most likely causes.
However, my experience on these older vehicles is you have a vacuum leak somewhere and it is causing it to be a little rich at idle.
Here is a guide that will walk you through vacuum leak issues:
If you don't find any vacuum leaks then walk through the possible causes on the attachment. If you need information on how to test some of these, let me know.
If you have a read out from the test, just post it to the site and I can take a look at it.
Thanks
May 21, 2019 at 4:44 PM
