high idle at startup no codes stays high, when I push on throttle engine revs up and down i have replaced tps and iac no change
Apr 5, 2016 at 12:39 PM
SATURNTECH9
CERTIFIED EXPERT
Have you checked for vacuum leaks ?
Apr 7, 2016 at 7:52 PM
EDDIESUEANN
MEMBER
Yes I Have can't find any
Apr 10, 2016 at 4:50 PM
SATURNTECH9
CERTIFIED EXPERT
How did you check for them?Also have you checked the coolant temp sensor?
Apr 10, 2016 at 4:52 PM
EDDIESUEANN
MEMBER
I checked them visually and with starting fluid sprayed all around with engine running no change
Apr 10, 2016 at 10:26 PM
SATURNTECH9
CERTIFIED EXPERT
The best way to check for vacuum leaks is by injecting smoke and watching for escaping smoke.Also the best way to spray around with carb spray method is to watch short term fuel trim and watching to spike while spraying around.also did you check the coolant temp sensor ?They can go bad not set a code and cause a high idle.
Apr 10, 2016 at 10:31 PM
EDDIESUEANN
MEMBER
I did check the coolant temp sensor it's ok also injected smoke the only place it came out was the egr so I replaced that still the same?
Apr 15, 2016 at 3:43 PM
SATURNTECH9
CERTIFIED EXPERT
So did you watch the coolant temp on live engine data while comparing the coolant temp to actual coolant temp?
Apr 15, 2016 at 6:10 PM
SATURNTECH9
CERTIFIED EXPERT
Also what are your tps readings in volts at idle?
Apr 15, 2016 at 6:28 PM
EDDIESUEANN
MEMBER
Ok here it is I couldn't find any problems untill I tested the coolant temp sensor and it showed low voltage so i went to the PCM it was loose and had worn 4 wires rubbed into I don't know how it still ran even with high idle anyway I fixed the wires now it runs fine who would know?
Apr 18, 2016 at 7:58 PM
SATURNTECH9
CERTIFIED EXPERT
Thru years of experience with coolant temp sensor issues I have seen really strange things you wouldn't think they could cause but your proven wrong lol.Glad to hear you found the problem and got it all back to normal again.
Apr 18, 2016 at 8:04 PM
EDDIESUEANN
MEMBER
I went all the way to the temp sensor which led me to the real problem Thanks again
