just to mention when I bought the car the previous owner had canceled the DPF
filter system These are readings I got on my ODB:.
P0183
Status: Calibration Supported DTC, Current DTC, Test failed
time since DTC cleared, history DTC, test not complete since power on, current DTC since power on, warning indicator required
Possible decryption (attention control module):
OBDII: Fuel Temperature Sensor A - High Input General Electrical Failure
[0x00] Click here to search the Internet for description ...
P2453
Status: DTC Supported by Calibration, Test Failed Since DTC Cleared, Test Failed Since DTC Cleared, History DTC, Test
failed from power on Possible decryption (attention to control module):
OBDII: Diesel Particulate Filter (DPF) Pressure Sensor A.
circuit failure
Chevrolet: A sensor circuit fault in the Diesel Particulate Filter (DPF); Diesel Particulate Filter (DPF) differential
Incorrect installation of the pressure sensor circuit.
Diesel Particulate Filter (DPF) Differential Pressure Sensor Circuit
Algorithm Based Errors: High Temperature [0x54] Click to search internet for description ...
P2282
Status: DTC supported by calibration, Test has failed since time
Clear DTCs, History DTCs, Test Failed Since Power On
Possible decryption (control module note):
OBDII: Air Leakage Between Throttle Body and Valves
Chevrolet intake manifolds: Mass air flow sensor failure
(MAF) based on [0x52]
Nov 1, 2022 at 12:00 PM
