Compression is high in all four cylinders 215 psi as should be 195, and starter is hard to turn over engine. Replaced starter, timing belt, clutch, pressure plate, flywheel, and power leads. fully charged good battery installed. What is making compression be high evenly and starter have trouble turning engine?
Sep 6, 2016 at 12:14 PM
