High beams do not work
1999 TOYOTA AVALON
333,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
LA300ZXTT
  • 9 POSTS
My high beams do not come on when “flashing” them or coming on like normal.
I’ve changed the dimmer switch.
The dimmer relay seems to work, checked with test light.
I might add my DRL's quit working also.
I have all other lights.
Apr 10, 2019 at 5:56 AM
Welcome to 2CarPros.
My first suspect us DRL relay 4. See the attached picture 1. Remove the relay and here is a link that you can use to check it.
Here are a few links that show how to use the test equipment. I have also attached a portion of the schematic of where the power comes from. I added it because it is different if you are in the US or Canada. I'm not sure where you are located.
I would also recommend checking the aforementioned fuses regardless of where you are located. They are specific to the high beam lights and DRL's.
Here are links to help with testing:
https://www.2carpros.com/articles/how-a-car-fuse-works
I hope something here is helpful. Let me know if you have other questions. Also, pictures 3 -6 are the entire schematic for your lighting system. I had to break them down to fit everything. However, I did overlap them so you can follow them.I'm adding them if you want to check anything else.
Apr 11, 2019 at 5:21 PM
LA300ZXTT
  • 9 POSTS
Thank you! I’ll check it.
Apr 11, 2019 at 5:54 PM
LA300ZXTT
  • 9 POSTS
In Louisiana btw friend.
Apr 11, 2019 at 6:00 PM
Welcome back:
Let me know the results. That relay is my first suspect because both DRL and high beam are controlled there.
Apr 11, 2019 at 6:09 PM
LA300ZXTT
  • 9 POSTS
Yes sir.
Apr 12, 2019 at 5:49 AM
LA300ZXTT
  • 9 POSTS
Checked dimmer relay again there is no continuity between the terminals after applying power to proper leads.
The #4 relay for DRL tests good.
Apr 12, 2019 at 10:12 AM
LA300ZXTT
  • 9 POSTS
Bought dimmer relay.
Be here next week.
I’ll report back with results.
Thank you JacobandNickolas!
May God richly bless you friend!
Apr 12, 2019 at 4:33 PM
You are very welcome. I will watch for your reply.
Apr 12, 2019 at 7:59 PM
LA300ZXTT
  • 9 POSTS
Have not got the dimmer relay yet, but I jumpered pins 30 and 87 for just a moment to see if the brights would work and they did! Bad dimmer relay.
Apr 14, 2019 at 2:36 PM
Good job. You got it. When you get the new part installed, could you confirm that it worked? Honestly, I don't see why it wouldn't, but I would still like to know.
Apr 14, 2019 at 3:19 PM
LA300ZXTT
  • 9 POSTS
Will do my brother!!
Apr 14, 2019 at 10:13 PM
Sounds good.
Apr 15, 2019 at 6:18 PM
LA300ZXTT
  • 9 POSTS
Dimmer relay changed and Amen, I got brights!
Thank you for your help brother.
Apr 16, 2019 at 4:15 AM
Welcome back:
Great!! And you are very welcome. Take care and let us know if we can help in the future.
Apr 16, 2019 at 8:49 AM
