High beams
1999 FORD CROWN VICTORIA
125,000 MILES • 4.8L • V8 • RWD • AUTOMATIC
All lights work except high beams. When I pull lever back no high beams no change to low beams. When I click lever forward all headlights go off. This is an old police car and you can definitely tell they stripped the strobe light box out. Extra wires from hood to trunk.
Feb 8, 2017 at 6:07 PM
STEVE W.
  • 15,113 POSTS
Either a bad multi-function switch or the wiring to the headlights has been "patched" after they removed the wig wag lights. High beam power from the switch is the light green with black wire. Follow it from either headlight and you will likely find where it is bad.
Feb 8, 2017 at 7:18 PM
I will check it first thing after work tomorrow and let you know.
Thank you
Feb 8, 2017 at 7:26 PM
STEVE W.
  • 15,113 POSTS
Fire and police vehicles get a lot of "custom" wiring and sometimes the way they repair the wiring (if the even do) after they pull out the gear is more along the idea that "hey it is going to the auction, buyer beware".
Feb 8, 2017 at 10:21 PM
Found the high beams they were connected to a wire that led to the trunk and just cut. Did some searching along the front of the frame and found the green wire you told me just cut, connected them and all is working great.
Thank you.
Also, found more wires connected to strobe light bulbs left in the car.
Feb 9, 2017 at 8:44 PM
STEVE W.
  • 15,113 POSTS
You are welcome.
Thank you for using 2CarPros.com.
Tell your friends, family and anyone else about us and please return with any auto related questions, we are here to help.
Feb 9, 2017 at 11:45 PM
