Need to swap my OEM HID's for halogens
2001 LEXUS RX 300
50,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
JBRISH
Because HID assemblies are too expensive where I live. If I were to remove the old ballasts, there would be two wires each side. I believe one is a control wire and the other is 12V. How do I hook up wiring for both high and low halogen beams? Do I need relays in this case?
Thanks!
Jan 15, 2020 at 6:38 AM
I have included the headlight wiring diagrams so you can see how the system works and which wires to connect to your HID system.
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Jan 16, 2020 at 10:41 AM
JBRISH
Hello, thank you for the diagrams. is the headlight 'ECU' for HID lights refer to the ballasts?
Jan 16, 2020 at 2:53 PM
I believe so. Do you have a picture of the ballasts?
Jan 18, 2020 at 9:55 AM
