Engine is a 350 TBI. When I attempt to accelerate the engine "hiccups", the RPM's drop, the vehicle jerks forward, and sometimes a light backfire is heard. Basically the more gas needed the more frequent and stronger the hiccups become (hills are the worse).
I have replaced the following since this has started:
Fuel filter.
Spark plugs.
Distributor cap.
Distributor rotor.
MAP sensor.
Ignition control module.
IAC (cleaned not replaced).
Engine coolant temp sensor.
I tested the PCV and found no leaks
Besides making the truck more responsive it did nothing for the actual hiccups. This only happens under load, If I rev the engine while in park it is smooth and sound strong no knocks or bangs. While driving at a constant speed there is no problems (does not matter the speed, only getting to the speed).
Other details:
No check engine light showing and no codes either.
Previous owner removed the catalytic converter.
Attempted to see if there was a change in idle with the O2 sensor unplugged but no change.
Strong smell of raw fuel coming from exhaust.
Tested each spark plug and all were strong.
Fuel filter.
Spark plugs.
Distributor cap.
Distributor rotor.
MAP sensor.
Other details:
May 8, 2018 at 7:00 PM
