1-starting the idle is not normal it stays hi (swinging revs 2500 to 3100) .
2-While driving (shaft on D Position) the engine sound goes hi (as if the gas peddle is pressed) the sound goes down (but still hi idle). Then
3-The car slows down to zero speed during that pressing on gas give no power to the car only the engine
respond . The shaft is still on D Position.
4- So the car stops ,the engine still on (with hi idle) To move on the car ,the engine must switch off and on again. The same repeats over again.
5- the above happens only when shaft on D .But not on 1 position.
6 the question is this an engine issue or a transmission issue ?
Note : the TSP is completely renewed but still getting error massages of PO123 and PO222
Apr 19, 2015 at 3:30 AM
