Dodge Neon with 2.0L manual trans. Starts perfect, idles fine, start acceleration and at about 2000 RPM the car hesitates until I get above 2000 RPM, then I get P0339 code and the car runs perfect. I can do start stops, high speeds and the car runs smooth, accelerates fine, runs like a normal engine. Turn key off, and when I start the car again I go through the same process. Finally after some amount of miles I get a P0315 code, the check engine light starts flashing, at that point my gas mile drops and at stop signs the idle is too high. Have replace sensors, coil pack, plugs, plug wires.
Aug 23, 2013 at 4:25 PM
