Hesitation from a stop
2004 NISSAN SENTRA
145,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
KATIE2007
My car drives fine, starts fine, but in town traffic makes it hesitates from a stop, like I have to pump the pedal for it to kick in to go. this does not last long maybe three seconds. no lights come on. we have checked the fuel fuses. The air mass sensor plug in. We put fuel additive in case there is junk In the tank. It does not do it at high speeds or constant movement. Only at stop lights and not all the time. my fiance can drive it rev it up to try to get it to do it and it will not do it. I drive slow and easy and it did it three times tonight. we are thinking it is the throttle body, but I am also thinking maybe the air mass sensor. I have tried popping it into second to see if it still does it and it does.
We have checked the air mass sensor just the plug it did not appear dirty. We changed the oil added coolant. It had a transmission flush in may. It has thrown the p0420 code a few times but I turn it off and it stays off for six to eight months and drives fine. No lights appear when it stalls no over heating nothing. However, tonight I did notice after it did it my dash lights were dimmer. Battery was replaced in May as well. And new battery connectors were added last month. If it was a sensor failing I would think the light would come on. I have also looked up fuel pump failure says overheating is a sign mine does not do that. some days it drives great other days it does not. this morning it ran great to work tonight not so much.
Jan 15, 2018 at 9:20 PM
MIKE H R
  • 3,094 POSTS
It being fourteen years old you might want to clean the throttle body. A little carbon will make it do it. Use throttle body cleaner. Make sure you follow instruction, you might have to do it a couple of times. I had the same problem on a Firebird.
Jan 17, 2018 at 7:12 AM
KATIE2007
I have noticed it only does it when it is running with the heater on high like a three or four it is odd. also know there is a rattling noise mainly in gear.
Jan 17, 2018 at 9:38 AM
MIKE H R
  • 3,094 POSTS
The heater part throws me off. when it is idling in neutral no noise. Then when it is in gear there is a rattling. I think that comes from the engine running rough . Still think it is in the throttle body. It is the cheapest way I can think to try first.
Jan 17, 2018 at 10:41 AM
KATIE2007
Will do, thank you very much.
Jan 17, 2018 at 11:54 AM
This guide should be able to help as well.
https://www.2carpros.com/articles/engine-hesitates
Jan 20, 2018 at 2:58 PM
