Engine Hesitation
2007 MAZDA CX-7
126,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
RALPH59
Car runs okay, but when turning A/C rpm's drop and shakes a little bit. Car never shuts off, no check engines lights.
Dec 7, 2019 at 12:58 PM
This is common when you have a vacuum leak or the throttle bore needs to be serviced. here are two guides that will help us fix the problem:
and
Dec 8, 2019 at 5:24 PM
This is normally caused a failed engine mount or transmission mount. Basically when they fail and the AC adds the additional load or stain to the engine it causes it to shake. More than likely it will get worse and start shaking or vibrating all the time.
There is a chance that there is a vacuum leak but I would start with the mounts.
Here is a bunch of info on the mounts. Let me know if you have questions.
https://www.2carpros.com/articles/how-a-motor-mount-works
https://www.2carpros.com/articles/replace-motor-mounts
https://www.2carpros.com/articles/vibration-noise
Dec 8, 2019 at 5:35 PM
RALPH59
I will check the engine mounts. but, why is it that the rpm's will go down when the AC is turned on? That's when the car shakes a little bit and notice the rpm needle moving up and down. The car never shuts off but feels like it would. If I turn the AC off it works fine.
Dec 9, 2019 at 6:16 AM
I would service the throttle bore first. Please let us know. Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response.
Dec 9, 2019 at 10:22 AM
