My car runs and idles normal when the engine temperature is low, with or without A/C, but starts idling rough and hesitating once the temperature goes up, with or without A/C as well. But it's very severe with the A/C on. The rough idling is consistent once it starts.
I've changed cold starting switch, mass airflow sensor, idle air control valve, intake air temperature sensor (airflow meter), plugs, high tension wires, oxygen sensor (the previous owner of the vehicle had the second oxygen sensor underneath the car removed and sealed), throttle body, fuel pump.
Apr 23, 2021 at 3:31 AM
