outside temperature gets to above 80 degrees my car starts to hesitate and buck
2004 HONDA CRV
95,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
GERHARD LANGE
When the temperature outside goes above 80 degrees my car starts to hesitate and buck but only. After driving the car for 10 miles or more it doesn't do it. if I am just driving a few miles also it does not do this when the temperature is below 75 degrees outside. what is causing this?
May 1, 2020 at 10:56 PM
We need to with checking fuel pressure when this happens. Normally when it is temp related like this a fuel related issue. We need to monitor fuel pressure when it is happening and see what it is doing. It should be pretty steady but if it is dropping or fluctuating then we need to dig deeper into this.
Here is a guide that talks about how to do this:
Just tape the gauge to the windshield so you can watch it while it is happening.
Here is a guide that talks about hesitations that we will get into if the fuel pressure is okay:
https://www.2carpros.com/articles/engine-hesitates
Let me know what the actual PSI number is, not just that it is good. Thanks
May 2, 2020 at 5:09 PM
