More than likely, it is not the crank sensor. Basically, this sensor tells the ECM the position of the crankshaft so that it can fire the plugs and injectors at the right time.
If there is no crank sensor signal, then the engine would not run at all. So, if you can keep it running above 3000 RPM then the crank sensor is fine.
This most likely is one of two things. Either a vacuum leak which is most likely. Or a fuel pressure issue.
So, let's start with a vacuum leak. Here are a couple guides that will help with this.
https://youtu.be/4ktw1X4W_-k
Basically, if there is a leak then there is air coming into the engine that is not being measured and the PCM does not know to add more fuel for that air, and it throws off the air fuel mixture which does not allow it to run properly.
Plus, here is a guide that will help with fuel pressure:
Please run through this info and let us know what you find.
Nov 23, 2021 at 7:06 PM
