Hesitates and stalls
2003 OLDSMOBILE ALERO
160,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
WILLIEDYNAMITE11
  • 37 POSTS
i replaced my spark plugs recently and now the vehicle is hesitating and high RPM's at stops or it's going to shut off one of the other. It has tape and stalls when meet. I was wondering if you could give me some insight on what maybe I should look at next? thank you.
Feb 24, 2020 at 11:08 PM
SCGRANTURISMO
  • 4,897 POSTS
High RPM's or "searching" RPM's at idle is usually a sign of a vacuum leak somewhere. This would also cause other driveability concerns like hesitation at high RPM's, which is dangerous for your vehicle. To check for a vacuum leak inspect the air intake track, throttle body, vacuum and EVAP lines. Look for broken or cracked vacuum lines. Also check around the intake manifold and listen for any hissing of air being sucked into the engine. Please get back to us with what you find.
Thanks,
Alex
2CarPros
Feb 25, 2020 at 12:05 AM
