Joe, I went through my shotgun answer from the past and the MAS is out of whack.
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/air flow meter.
Throttle position sensor.
Crankshaft position sensor.
Knock sensor.
Manifold absolute pressure sensor.
EGR Valve.
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Thank you. Have a nice day, see you again someday-take care and be safe.
Jul 20, 2021 at 12:21 AM
