If the light is blinking, that indicates a misfire it happening. This can lead to other problems so we need to determine what is happening. The first thing I need you to do is have the computer scanned. You will need a scanner to do this. Here is a quick video showing how it is done:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but often times, a parts store will do it for you.
Now, what I believe is happening is you feel the misfire while accelerating because one or more of the engine cylinders aren't working. Thus, it runs rough, has less power, and the check engine light blinks. Once you reach speed and are lighter on the throttle, you don't notice the issue as much because there is less of a load on the engine.
Take a look through this link:
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
Have the computer scanned so we can determine which cylinder is causing the problem and get it fixed. When a misfire happens, it can allow raw fuel to enter the catalytic converters and damage them. They are expensive to replace.
Let me know what you find and I will be happy to help you get it figured out.
Jan 30, 2019 at 5:30 PM
