Help with trouble codes please
2020 KIA FORTE
3,063 MILES
ERICK GREEK
I received a tow last month to the impound lot.
There was absolutely nothing wrong with the vehicle when I last used it.
Now when I turn it on i get these trouble codes.
ABS , esc check forward collision avoidance assist system.
Check blind spot warning system.
And the master warning mode light.
Sep 28, 2020 at 11:52 PM
STEVE W.
  • 15,113 POSTS
Could you post the actual code number please? That helps in diagnosing the issue as there are multiple codes possible for all of those systems and each points to different problems. Being this is a 2020 you may want to just have a dealer look at is as it should be under warranty and covered. However if you post the codes we may be able to give you an idea of what is wrong.
Sep 29, 2020 at 7:57 AM
