It could be any of the things you mentioned. Additionally, a partially plugged fuel filter or weak fuel pump can cause it.
If you were to bring the vehicle to me, here is what I would be checking. First, I would confirm there isn't a vacuum issue related to the PCV valve hose. Additionally, I would test for vacuum leaks. Here is a link that explains how it's done.
If I determine there are no leaks, I would next check fuel pressure. You will need a fuel pressure gauge to do this, but most parts stores will lend one to you. Here is a link that explains in general how it's done:
At this point, testing of fuel flow through the injectors, engine compression, a faulty oxygen sensor, and the list goes on can cause it.
Let's get through checking the PCV, checking for vacuum leaks, and fuel pressure. I have a feeling the problem is with one of these things.
If you look at pic 1 below, it shows the PCV valve. Check the hose and the grommet that the PCV presses into for leaks. That is on the driver's side valve cover. Pic 2 provides the manufacturer's fuel pressure specifications. Make sure to pay attention to how quickly the pressure drops when the key is turned off.
See pics below.
Aug 25, 2022 at 7:32 PM
