Not starting but has power?
2011 INFINITI G37
137,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
JAY FERRY
Okay, hello, i appreciate your help. So, i drove the car all day, I stopped for about an hour and when i came back the check engine light turned on and it shifted hard into drive. i drove it for about a mile when i noticed it was stuck in second from the start. I parked the car and when i tried to restart it the power came on and everything worked. But when i pushed the brake and the ignition there was nothing. Also, most like it's in lock out mode. Also, the key light in on in the dash.
Aug 1, 2022 at 7:19 PM
The fact that the key light is on means the security system is engaged but I think it might be a battery issue. So, let's use this guide to load test the battery, it's easy. Then if okay let's run the codes to see what comes up. you can get a code scanner from Amazon for about $20.00.
Here is a video to show you how. but first:
and
Here is a scanner link:
https://amzn.to/3Qi1SS6
Aug 2, 2022 at 8:15 PM
