This problem is intermittent, starts runs fine other times when attempting to start it kicks back on the starter. shows a heavy amp pull on the battery which is new. checked out the starter, replace the crankshaft position sensor problem still exist. it will crank easy and then like a kicks back and has a hard time turn the engine over. no signs of oil or antifreeze mixture or bubbling in the radiator, no antifreeze smell in the exhaust when it is running, no check engine lights, battery cables tight, and secure. I am really stumped here is it hydraulicing should I run a compression check next?
Jan 5, 2018 at 9:08 PM
