Misfires on cold start
2002 SATURN L200
108,000 MILES • 4 CYL • AUTOMATIC
MANDY9395
Problem started a few months back. Car misfires when i start cold. Stops misfiring when warmed up completely. I have changed catalytic converter , fuel pump , fuel filter , ignition module, all spark plugs and all injectors. Check engine light on throwing code cylinder two misfire. But in the beginning threw code cylinder one misfire. i replaced the injector and spark plug for cylinder one. Ran good for two months, now says cylinder two misfire. The mechanics i have taken it to cannot figure it out so i am looking for online help.
Jun 8, 2017 at 4:34 PM
A cold engine misfire many time is caused by the MAF sensor. When these sensors go out they may or may not trigger a check engine light,
Here is a guide to help you
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
Also it could be a vacuum leak, here is guide for that as well.
Please run some tests and get back to us so we can continue helping you.
Jun 12, 2017 at 1:44 PM
