Welcome back:
I don't know if you want them, but here are the directions for replacing the pump on your vehicle. The two attached pictures correlate with the directions.
____________________________
2013 Chevrolet Cruze L4-1.8L
Water Pump Replacement
Vehicle Engine, Cooling and Exhaust Engine Water Pump Service and Repair Removal and Replacement Water Pump Replacement
WATER PUMP REPLACEMENT
Water Pump Replacement (1.8L LUW and LWE)
Removal Procedure
1. Drain the cooling system. Refer to Cooling System Draining and Filling (Static Fill) See: Cooling System > Procedures > Cooling System Draining and Filling (Static Fill)Cooling System Draining and Filling (GE-47716 Fill) See: Cooling System > Procedures > Cooling System Draining and Filling (GE-47716 Fill).
2. Remove the water pump pulley. Refer to Water Pump Pulley Replacement (1.8L LUW and LWE) See: Drive Pulley, Water Pump > Removal and Replacement > Water Pump Pulley ReplacementWater Pump Pulley Replacement (1.4L LUV) See: Drive Pulley, Water Pump > Removal and Replacement > Water Pump Pulley Replacement.
pic 1
3. Remove the 5 water pump bolts (2).
4. Remove the water pump (1).
5. Remove and DISCARD the water pump seal ring.
Installation Procedure
1. Clean the 5 water pump threads.
2. Clean the water pump sealing surface.
3. Insert a NEW water pump seal ring.
pic 2
4. Install the water pump (1).
Caution:
Refer to Fastener Caution See: Vehicle > Technician Safety Information > Fastener Caution.
5. Install the 5 water pump bolts (2) and tighten to 8 Nm (71 lb in).
6. Install the water pump pulley. Refer to Water Pump Pulley Replacement (1.8L LUW and LWE) See: Drive Pulley, Water Pump > Removal and Replacement > Water Pump Pulley ReplacementWater Pump Pulley Replacement (1.4L LUV) See: Drive Pulley, Water Pump > Removal and Replacement > Water Pump Pulley Replacement.
7. Refill the cooling system. Refer to Cooling System Draining and Filling (Static Fill) See: Cooling System > Procedures > Cooling System Draining and Filling (Static Fill)Cooling System Draining and Filling (GE-47716 Fill) See: Cooling System > Procedures > Cooling System Draining and Filling (GE-47716 Fill).
________________________________
Let me know if this helps and what you find.
Oct 14, 2019 at 8:58 PM
