Jeep WJ, at first for two days I had intermittent power to the AZC climate controls. Now nothing. The temperature display does not light up at all and adjusting the mode or speed does nothing. If I hit the rear defrost button I hear a click but that is all. I replaced the blower motor resistor on advice from a friend and still no luck. I have check fuse 20 in the cabin and replaced it along with fuse 7 under the hood. Used a light tester to test my other fuses and everything seems good. Any help is greatly appreciated as it's my only vehicle and it's starting to snow out.
Jan 18, 2019 at 9:41 AM
