Help
2001 NISSAN PULSAR
360,000 MILES
TIMLANA
Hi my Nissan pulsar has just had a head gasket repair it was starting fine since been put back together it won't start only turn over thinking the timing may be out also it seems to not have much compression
Apr 26, 2013 at 4:06 AM
HMAC300
  • 48,601 POSTS
check to see if timing belt is correct it may have jumped or not installed correctly. you may have bent valves in cylinder head as well. we don't have a pulsar model in u.s but if you give me engine size I may be able to give you comparable settings and whether single or dual cam
Apr 26, 2013 at 7:03 AM
