Purchased this vehicle non op. did some repairs at mechanic shop got it running, but did not drive it cause brakes were out. At an idle it started to over heat. changed water pump, thermostat and radiator, still over heating. mechanic said it is the head needs a valve job. i said lets just do a complete rebuild engine and transmission. Done! changed the tire, rims, interior, bumpers, lift and paint. Done! looks great! now the vehicle will not idle keeps turning off. mechanic said needs a carburetor adjustment and timing is off. Done! now idles perfect and cranks up right away. finally jump in to go for a ride after waiting since February of 2017, and it will not go past first gear and the automatic shifter on the column feels like a knife cutting through butter. called the transmission guy, he says well we put all together and had it on the rack went through all the gears just fine. Help!
Nov 6, 2017 at 5:10 PM
