Steering wheel locked and car will not start?
2007 MINI COOPER S
137,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
MIKEAMOSMIKE
Steering wheel locked and car won't start?
Sep 3, 2025 at 10:18 AM
Yep, this happens when the battery is dead or low on charge, I would lift the hood and use a voltage meter to see what the surface voltage is, also keep the meter on the battery as you turn all of the lights on, it should stay relatively the same (about 12 volts).
This guide can help:
Sep 3, 2025 at 6:12 PM
