When the transmission skips from 1st directly to 3rd and then goes into limp mode, that is a classic fail-safe strategy. What kind of scanner are you using, usually the car will have one or more of these codes:
P0715 - input speed sensor
P0720 - output speed sensor
P0750-P0760 - shift solenoid faults
P0733 - incorrect gear ratio
Is the speedometer working? I would try servicing the transmission by changing the fluid out. The input/output speed sensors will cause this problem FYI. Also, you might want to try a hard system reboot this video will show you how.
https://www.youtube.com/watch?v=INiDRO5A5MY
This guide can help you service the transmission
Please go over this guide and get back to us. Ken
Mar 13, 2026 at 9:49 AM
