Good morning,
No, there is no pilot bushing for this. I attached the alignment procedure for aligning the disc and plate below along with the procedure for the clutch replacement.
https://www.2carpros.com/articles/how-to-replace-a-clutch
https://www.youtube.com/watch?v=57ATX4ThUjQ
https://www.youtube.com/watch?v=NcTmlO9XN1E
CLUTCH UNIT INSTALLATION
1. Install clutch disc and clutch cover on flywheel.
a. Insert Special Service Tool (SST) 09301 - 00220 in the clutch disc, and then set them and the clutch cover in position.
b. Align the matchmarks on the clutch cover and flywheel.
c. Temporarily tighten the topmost bolt from the 3 near the knock pins.
HINT: Temporarily tighten the No.3 bolt.
d. Torque the bolts on the clutch cover in the order shown.
Torque: 19 N.m (14 ft. lbs.)
2. Check diaphragm spring tip alignment.
Using a dial indicator with roller instrument, check the diaphragm spring tip alignment.
Maximum non-alignment: 0.5 mm (0.020 in.)
If alignment is not as specified, using SST 09333 - 00013, adjust the diaphragm spring tip alignment.
3. Apply molybdenum disulfide lithium base grease.
a. Apply release hub grease to the following parts.
- Release fork and hub contact point.
- Release fork and push rod contact point.
- Release fork pivot point.
b. Apply clutch spline grease.
- Clutch disc spline.
HINT: Recommended grease part number 08887- 01706 (1009).
4. Install release bearing and fork to transaxle.
Install the bearing to the release fork, and then install them to the transaxle.
5. Install transaxle to engine.
Mar 3, 2021 at 2:00 AM
