Car shuts off when fuel tank down to half a tank
2000 DODGE STRATUS
38,000 MILES • 2.5L • V6 • 2WD • AUTOMATIC
RICK JOHNS
  • 16 POSTS
I got it down to a half a tank of gas or a little less a car shuts off at a stop sign or anytime. but starts right back up and goes again.
Jun 21, 2019 at 10:20 AM
Good afternoon,
It sounds like the pick up in the fuel tank may be the issue. The hose connecting the pump to the pick up may have a hole in it not picking up fuel when the level gets to that point.
Jun 21, 2019 at 12:29 PM
RICK JOHNS
  • 16 POSTS
It is, canister type pump.
As long as your driving on highway it's fine until you slow down and stop.
Jun 22, 2019 at 8:07 AM
I know the design.
Based on your input from the original post, it indicates it is not picking up fuel.
https://www.2carpros.com/articles/stall-at-idle
Can you check the actual pressure?
Jun 22, 2019 at 11:23 AM
RICK JOHNS
  • 16 POSTS
Got to get an adapter for my tester.
Jun 22, 2019 at 11:43 AM
Okay, keep me updated.
Jun 22, 2019 at 11:44 AM
RICK JOHNS
  • 16 POSTS
Only, shuts off when stop,or turn.
Then no issues as long as driving .
RICK JOHNS
  • 16 POSTS
Fuel pressure within specs.
Jun 22, 2019 at 1:18 PM
What is the exact pressure?
Jun 22, 2019 at 1:20 PM
RICK JOHNS
  • 16 POSTS
57.
Jun 22, 2019 at 5:22 PM
Okay.
Jun 23, 2019 at 3:51 AM
You need to test it when the engine acts up and be sure it is the same pressure.
RICK JOHNS
  • 16 POSTS
Can't only mess up, driving. Had to make adapter, no fuel valve, so can't check while running.
Jun 23, 2019 at 5:53 AM
You need a kit that will T into the fuel rail so you can drive it while watching the pressure.
You can rent these testers at a parts store.
Jun 23, 2019 at 6:00 AM
RICK JOHNS
  • 16 POSTS
It's canister type pump.
Jun 23, 2019 at 12:28 PM
RICK JOHNS
  • 16 POSTS
Yes, but how can I read pressure,while driving?
Jun 24, 2019 at 9:56 AM
You need a tester with a long hose so you can view it on the windshield. That's what we do when we road test.
Jun 24, 2019 at 2:07 PM
RICK JOHNS
  • 16 POSTS
Today,I got gas and tank not under pressure?
Jun 24, 2019 at 8:39 PM
Tank not under pressure? Please explain.
Your tanks are never under pressure. The fuel pump creates pressure in the fuel line.
Jun 25, 2019 at 2:37 AM
RICK JOHNS
  • 16 POSTS
Yes,when I remove cap to put on gas there no pressure.
Jun 25, 2019 at 7:47 AM
That is normal. The pressure should in the line to the injectors.
Jun 25, 2019 at 8:13 AM
RICK JOHNS
  • 16 POSTS
New pump, same issue.
Jun 26, 2019 at 5:26 AM
Did you verify power to the pump when you had it apart? The power comes down th line from the inertia switch to the switching valve to the pump.
Jun 26, 2019 at 6:41 AM
RICK JOHNS
  • 16 POSTS
Yes.
Jun 26, 2019 at 7:12 AM
New or used pump. Was there power?
Jun 26, 2019 at 7:43 AM
RICK JOHNS
  • 16 POSTS
New, and yes.
Jun 26, 2019 at 8:30 AM
Did you verify the issue with a gauge when it happened?
When you replaced the pump, did you look inside the tank at the baffles? A broken baffle in the tank will allow fuel slosh and that would cause it to lose pressure.
Jun 26, 2019 at 1:08 PM
