Help!
1994 ISUZU TROOPER
ADELYNNSMOM
The throwout beraring went out in my 1994 Isuzu Trooper so my husband replaced the clutch, after replacing the clutch the Trooper was makin this awful noise so my husband also replaced the slave cylinder. he has redone the clutch 3 times thinkin maybe he did it wrong & now it goes into gear & everything but it makes this awful grinding sound. what could it be?
May 5, 2013 at 7:21 PM
CJ MEDEVAC
  • 11,004 POSTS
MAYBE A LITTLE MORE INFO?......ENGINE SIZE?........4X4?
WHEN DID THE RACKET START? (CIRCUMSTANCES)
DID IT HAPPEN ALL OF A SUDDEN......OR GET WORSE AND WORSE?
IS IT THE EXACT SAME RACKET NOW----AS IT WAS IN THE BEGINNING?
IS IT CONSTANT?
GOES AWAY WHEN YOU PUSH THE CLUTCH PEDAL?........CHANGE IN THE SOUND?
ONLY WHEN CLUTCHING?
DRIVE OK WHEN IN GEAR.....SOUND GOES AWAY?
PLENTY OF ROOM FOR ANY OTHER STUFF YOU CAN THINK OF!
THE MEDIC
May 5, 2013 at 9:54 PM
