Squealing when started and when turning
1995 NISSAN ALTIMA
85,000 MILES • 4 CYL • 2WD
APRILLOWE1104
would like to know why my cars squealing bad when i start it up and when i turn.
Sep 10, 2019 at 9:35 AM
94 TRANSAM
  • 680 POSTS
Hi and welcome to 2CarPros. Lets get you fixed up here.
Engine squealing is usually caused by a slipping belt. To see if this is your issue you can spray the belt or belts with WD-40. When doing this make sure you spray the under side of the belt with the groves on it. Not the flat side. And be very careful not to get your hands caught in any moving parts.
Simply start the motor and spray the under side of the belt as it comes into one of the upper pulleys on the motor. You can usually stay about 6 to 8 inches away so you don't get hurt. If this is your issue the squealing will stop until the WD-40 dries up then it will start again.
If there is more than one belt, spray one at a time and change the one that stops squealing when sprayed.
If you need any help with changing the belt let me now.
Rich.
Sep 10, 2019 at 2:33 PM
