Transmission not shifting at thirty to thirty five mph
2012 CHRYSLER
115,000 MILES • AUTOMATIC
CRUZWILL88
Hello, when i start driving my car, when I reach about thirty to thirty five mph, I have noticed it seems like it does not want to shift gears. This has never happened before. I always take my car to Wal-Mart for an oil change, and from my understanding they are suppose to make sure that all fluids are filled and accurate. Any suggestions on what this issue is? I took it to Auto Zone, and they ran a quick test. Definition: Code P0733 indicates an incorrect ratio for Gear 3 for a predetermined period of time. The results from the car Error Codes Read: P0733 Gear 3 incorrect ratio (transmission shift solenoid), P0882 TCM power input signal low (transmission solenoid/pressure switch). Also, the Auto Zone worker suggested maybe purchasing a sensor (transmission oil pressure) Duralast, part number SU8494. If this information helps, I appreciate you in advance for the feedback! My car has 120,000 miles. My car has an automatic transmission.
Feb 14, 2017 at 7:24 AM
HMAC300
  • 48,601 POSTS
your transmision is in what is called limp mode have a transmission professional check this out as it can be a shift solenoid or another internal problem. see picture it shows causes and most are internal problems not shift solenoids.
Feb 14, 2017 at 8:17 AM
CRUZWILL88
Alright, I appreciate your feedback sir. Is this normal? Or do you believe it is time for a new ride!?
Feb 14, 2017 at 5:29 PM
HMAC300
  • 48,601 POSTS
transmission problems crop up for various reasons. see what the problem is before deciding on getting another car.
Feb 15, 2017 at 6:29 AM
