Heavy white smoke from exhaust
1993 FORD F-150
200,000 MILES • V8 • 4WD • AUTOMATIC
TAMA MOFFITT
I’ve just started getting heavy white smoke from the exhaust. Does not smell like rotten eggs.
Dec 9, 2019 at 3:41 PM
AL514
  • 5,464 POSTS
This can be a fuel injector stuck open, I've had this same issue in the shop, fuel injector stuck open pouring white smoke out of the exhaust. What you can do, is unplug each injector one by one until it stops smoking. And this way you can identify the problem quickly and rule out the injectors if it doesn't stop smoking. Just don't break the injector clips.
Dec 9, 2019 at 5:17 PM
TAMA MOFFITT
I will give that a look. There is also blow back oil in the air filter area. I’ve changed the PCV along with an oil change and new air filter, and still getting oil in the air filter.
Dec 9, 2019 at 5:28 PM
TAMA MOFFITT
Would this also cause poor start and acceleration?
Dec 9, 2019 at 5:31 PM
AL514
  • 5,464 POSTS
Oil in the air filter box is caused by excessive carbon build up in the crankcase. You may want to try an oil additive to break up some if the deposits. When the oil passages get clogged up, too much pressure builds up and forces oil into the wrong areas.
Dec 9, 2019 at 5:34 PM
AL514
  • 5,464 POSTS
A leaking injector can cause poor everything, the computer may be seeing too much fuel in the exhaust and cutting back on the amount but of fuel being delivered, this is called fuel trim. The computer can go positive with fuel trim numbers, ie adding fuel to the mixture, or the opposite negative numbers, reducing fuel.
Dec 9, 2019 at 5:43 PM
