AC was working fine then when it got cold “winter” we put it on the heater. It would not blow hot air. The velocity of the air works fine but I can turn it up to 88 degrees and it is normal or cold air. I did feel a tad bit of heat drizzle out on the driver side but wife’s side was still cold it would constantly be cold air but if I keep it on low velocity sometimes a little heat would slip out but when I felt the heat I would turn it up and it would go cold again. Tired of freezing checked fuses and all look good not sure what to do. I do not think my AC is working either now, but do not know for sure because it has been so cold outside all I want is heat.
Dec 28, 2017 at 7:21 AM
