Car somewhat struggles to fully perform when going uphill. After some time, the engine overheat indicator lights up. After checking with the local mechanic, I changed the head gasket (checked the engine head for any leaks. No leaks), changed the thermostat valve, changed engine oil and coolant and cleaned radiator. But I still have the same problem. It does not happen often as before. But the issue is still there.
Jun 6, 2023 at 11:58 PM
