Very weird problem. Car has the auto sensor lights, if the lights are on because of the sensor the heater will not turn on, and the heater will not turn on if the sunroof is open either. Last thing I noticed is the heater will not come on unless the water temperature is up to 200. Battery cables have been checked and did not find any problem. Heat instrument cluster has been pulled out and checked all connections. Fuse has been checked. I have plugged in my scanner and it shows no codes at all.
Nov 18, 2017 at 9:38 PM
