We've had below zero temps the past few days and I haven't driven anywhere. When I got in my car this morning, the heater would not blow air. Also, the rear defrost doesn't work.
We've discovered in the past that there isn't an accurate fuse diagram either in the manual or online. My husband decided to just check all fuses. He did find a 15 amp fuse that tested bad, the fuse itself is fine, but the outlet it plugs into tests dead? This may or may not have anything to do with our problem, but that's what we're dealing with.
Any suggestions besides paying $$$ to go to VW dealership?
Thank you!
Thank you!
Jan 29, 2014 at 9:58 AM
