HEATER does not BLOW air
1999 JEEP WRANGLER TJ
130,000 MILES
CHAD DOWNS
Heater, air conditioner and defrost is not blow out air on any setting. Changed fuse, no joy.
Where do I go next?
Nov 20, 2016 at 5:10 AM
BUCHANAN BEATON
ive changed the resistor blower motor my climate controls checked each fuse i still have nothing 97 jeep tj
Dec 12, 2019 at 11:17 AM
There is a blower motor relay that needs to be checked and check for power at the fuse and ground at the mother here is a guide to help you test the system and the blower motor wiring diagrams below so you can see how the system works.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
and
Blower Motor Relay In wire harness connector, near right end of heater-A/C housing.
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Dec 12, 2019 at 12:43 PM
