heater will only blow on middle vent
2003 MERCURY SABLE
130,000 MILES • AUTOMATIC
LJHESSE
My heat will only blow on middle vent we have change the air door actioner(sp) when you put new one back in will not work but you can turn it manually .Is the a value some were that I need to look at
need to get defrost to work and soon as cool weather is upon us
Dec 4, 2015 at 10:13 AM
JOHNNYT73
  • 924 POSTS
Try disconnecting the battery for a little while after installing the new and see if that helps.
Dec 4, 2015 at 11:02 AM
