That appears to be right at the compressor. The second pic above is a video, but I'm unable to play it.
If the two connectors you indicated leaked, first make sure the steel tubing wasn't damaged. If they are good, then there is an o-ring on each one that will need to be replaced.
Once that is done, you will need to vacuum and recharge the system. While the system is vacuumed, you can turn off the vacuum pump and allow the vehicle to sit. If there is a leak in the system, you will lose the vacuum.
Here is the link that explains how it's done:
With all of that in mind and if you are certain all freon/charge is gone, remove the hoses for inspection of both the steel hoses and the O-rings.
Let me know what you find.
Dec 12, 2022 at 6:52 PM
