heater switching from heater to ac and back
2000 FORD F-150
247,000 MILES • 4.2L • 6 CYL • 2WD • MANUAL
MITCH WILLIAMS
I have replaced the thermostat and there is enough water the heater blows cold air I have cut a hole where heater box is and cant make blend door move .somewhere there is a heater vale that makes the system switch from ac to heat can you tell me where that is and how it works electrical or vacuum?
Jan 18, 2016 at 12:50 PM
HMAC300
  • 48,601 POSTS
the blend door is electric and it's behind center of dash see pic for instructions and tip. also try removing hvac fuse inside truck with key on for 60 seconds that may reset it to work.
Jan 18, 2016 at 1:17 PM
