I posted this issue late last year, well here I am again with the same problem. To make a long story short, I took my car to the Honda dealer since I have no heat and they explained that the heater core is clogged and it has calcium buildup, they wanted about $700.00 for a flush. I did a simple water flush with the garden hose last year and bright green coolant came out the other end, no crud or buildup of any sort. I did the same procedure today but a lot more thorough, water flushed it then reverse flushed it, then I poured CLR on one end of the heater core, let it sit for about 15 minutes, then rinsed it out with water and repeated the same step on the other side, with multiple reverse flushes, clean water came out both sides and I still have no heat. Attached are the images I took of the temperatures for each vent and both heater hoses once I put everything back together and let the car run for more than half an hour.
Nov 13, 2020 at 12:38 PM
