Hi
heater problem but this is not a land rover. it is an ldv pilot camper van land rover was the closest match. The core is not heating up, its an old diesel ldv van ( british) I have put in a new thermostat and topped up coolant, changed the heater open close valve for new the cable works as i have had the dash out and moved the valve manually I also flushed the core with a hose the pump seems fine as the water pumps out when the hose is taken off the core and the engine temperature gets up to normal when idling and the fan works on the radiator and the heater fan also works,,,,,,,,,,,,,,help could it be air in the system ??? im really stuck on this one
many thanks jeff
many thanks jeff
Jun 3, 2014 at 5:18 PM
